Different cam and crank sensors?
cantgo2fast
188
Jul 2, 2009
Fort Collins, Colorado
Hey guys just picked up a replacement set of cam and crank sensors, I broke one and just decided to replace both.
When I got them from Stangmurdera both of them were flat 3 pin plugs off a 97 7bolt motors.
The ones on my car are one three pin flat plug and triangle plug. see pics. The two on the right are the ones from my car. the on on the right is the one I got, they are identical
The cam sensors differ between the '95 and '97, so the plugs may differ as well.
Well the plugs will for sure be different. The cam sensor plug on a 2gb is apart of the harness and plugs directly into the CAS. Where there is a pigtail running from the cam angle sensor on the 2ga to the square plug. The sensor I see in the picture is the cam angle sensor but I don't see a picture of the crank sensor. You might just have to find a 2ga CAS plug.
