Wiring 3 gauges together to speaker wire
BostonGST
175
7
Feb 28, 2014
Los Angeles, California
I did some searching and believe i am right on this but want to be 100% sure before I do it. So I just bought a boost, oil pressure, and wideband guages and a lotek pillar. I know how to wire everything up, my question is for all of the power wires for the gauges, can I solder them into a speaker wire then hook up that speaker wire for power? And do the same with ground on another speaker wire? So instead of having 3 power and 3 grounds i'll have one speaker wire for each hooked up.. This will work correct?
Speaker wire can work if you get the proper gauge. You will need to look at the draw of the 3 gauges to determine wire gauge.
Personally I don't like to use speaker wire.
