Wire harness plugs ? were do they go?
danyz250f
631
6
Mar 13, 2005
Rexburg, Idaho
I am putting my motor in and on the part of the wire harness that is on the fuse block that is kinda on the battery there is two plugs I cant find were they go. One plug looks like the maf plug but wider. The other plug takes three pins, but is like the size of the maf plug. I am just using the maf plug as a reference size, because most people can rember what this one looks like.
I would post pics but I am at work and my car is at my friends house. I looked for like 15 minutes but I was tired and it was dark and my friend unplugged them. Thanks for your help.
Above the battery tray or below.
I check my GF s car and its a tsi awd and is stone stock. It is a jumbled mess of wires loom and vacume lines. It was hard to see any plugs at all.ROFL
As stated above there is one plug on the firewall kinda next to the battery tray, and the othe rplug on that harness plugs into the transmission about half way between the engine and tail of tranny. those are the only 2 plugs that i know of on that battery harness. i am assuming you are referring the battery/charging/starter harness?
hope this helps!
one could be the plug for the air conditioning just infront of the fuse box...ill look at one of my parts cars and post if no one has gotten it for you.
