2G Windows are stuck down Spyder GST?
Antonio Brown
51
7
Oct 13, 2014
Tampa, Florida
So yesterday I let down all of my Windows on my 97 Spyder GST and my Driver window let's up and down but the other three passenger and the two rear Windows are stuck down. I checked the fuses and even tried changing them. I unplugged the battery for thirty minutes and still the same issue. I even took the driver door panel off and tried unplugging the master window switch and still nothing can anyone tell me what the problem could be? The convertible too let's down and up fine.
Take off the switch panel on the DS door and check the connection at the main switch, could just be a loose connection. If it's not that check the window relay, B-42X on the attached diagram.
The Driver side master window switch was the coulpret. I replaced it last Friday. There was only one junk yard nearest to me that had a Spyder.
