rear quarter windows on spyder stuck down
TeacherCreature
Apr 26, 2013
Middletown, New York
I got a spyder and the little rear quarter windows went down one day never went back up..
I put a new window switch and all fuses are good , is there a relay? I looked in engine bay and done see it , thanks for any help
Where is this computer or is that the same module as under the seat that the otehr member mentioned?
I havnt gotten to it - been raining nonstop in NY
Ok so I got the seat off and I see two electronic parts
The one on the left is smaller and the one on the right is larger?
Neither of them seem cheap and I hope I dont have to replace the whole thing,
someone mentioned above that I can change or may need to change a relay "in" the module, so do I just open one of them up and find a relay?
I appreciate the help in the newbie section :)
Ok so upon further inspection the one on the left is a box labeled remote door locks and is connected to what appears to be an external relay. In side the remote door lock box is a green circuit board
Then the box on the right is larger but has no relays i can discern, if I open the box up there is a large circuit board with what seems like relays but they are soldered in.
Am I looking at the wrong thing or did u mean undsolder and resolder? or do I have to change the whole unit.
