Spyder power windows
greyspyder117
373
Oct 13, 2008
Bronx, New York
I did a search and didn't find what i was looking for. My driver window works fine in my 97 eclipse gst spyder but the passenger and the two lil back windows won't go up or down has anyone ran into this type of problem before please help
Is your window lock button on? LOL Yes it locks the other windows even on your control...
If its not, pull the door panel off and make sure the plug it securly in, when I put it in, 1 was loose and only the drivers window worked.
Do the motors make any sound? Which switch are you using the top button or the ones on the drivers door? I know on my spyder if I use the top switch one of my back windows will not go down. I also say check to make sure the window lock button is not on. If thats not it maybe the drive switch assembly is bad.
No i am not using the top switch and no the lock button isn't on but i am thinking what if it shorted out. Is that possible? The lock buttons work and like i said the driver window is fine. Is the lil windows in the back on serpret motors ?
