Window stuck open
red97tib
524
4
Mar 27, 2007
Des Moines, Iowa
You mean the window is stuck to where it wont move, or its set to where there is a huge gap from the window and the door? If its the later, you need to adjust the tracks inside the doors.
The window moves up and down perfectly fine. The problem is the gap between the glass and the car. I have had my panels off half a dozen times and there doesn't seem to be anything wrong there. It's almost like the glass is bent so it doesn't fit the door frame.
Looks to me like the rubber seal is either worn or just not in the right position. Try messing with it some.
Has that car been broken into in the past? Looks like that glass had been levered-out. Hard to guess over the web, but look for the positioning and condition of the rear guide inside the door.
  • Wanted 6 bolt NT water pipe
    • chrisman287
