Will this work *fuel system*
leepen
577
10
Dec 17, 2006
Las Vegas, Nevada
After reading about fuel systems for 2 days, my eyes are crossed. Ok long story short I was going to run all -6 lines and fittings. But I was sent a -8 FR fitting so figure WTH Ill run -8 from the tank to the FPR to the FR. My concern is the -6 in and -6 out on the FPR (choke point) and is this to much fuel.
e85
AEM FPR
duel wallys
1600 injectors
link
GT35r
thanks :thumb:
No ones running -8 lines with a -6 FPR, with any input on this???? help
with 1600s and e85, I doubt you can have TOO much fuel haha. Well of course you can have too much, but that depends on your tuning. 8an lines should be fine though. What are you using to tune?
Why are you running it through the AFPR first? Run from the tank to a -8 fuel filter to the rail then -6 from the rail to the AFPR for return. This setup has been used quite a bit and is enough for a lot of power.
Making 550whp on E85 w/ my other talon using stock fuel lines stock fpr and 1650cc injectors.The stock system can handle alot.
yes that was my um FAILZ:shhh:, all good now thanks
link
