Will this replacement fuel tank work?
For me it is listing the GSX model also. Sorry the link doesn't seem to be working for me but here is a screen shot.
GSX tank has to accommodate for the drive shaft, so there is a big "hump" in the middle of the tank to account for that. Also, I believe there is a difference in 2GA and 2GB filler necks or ventilation or something along those lines that affects filling it up at the gas pump.
Thank you. I will try to find another option.
The 95-97 and 99-99 tanks are different, because the filler pipe is also different. The venting is very different and a GSX tank should have a second opening just like the one for the fuel pump. It should be on the passenger side in about the same equivalent place as the drivers side.
I bought a 1g gas tank with fuel pump assembly and filler neck from millers..... asked for a perfect tank, that's what I got
