Will this water neck fit ?
Phalanx99
62
Apr 22, 2006
Garden Grove, California
I have a problem with the radiator hose that comes from the water neck to the radiator. My intake pipe hits the hose so I need to move the hose and the water neck to a different angle. I found this straight water neck on ebay :
http://cgi.ebay.com/ebaymotors/Mopa...5QQihZ020QQcategoryZ33602QQrdZ1QQcmdZViewItem
Just wonder if it wil fit on my 4g64 block ?
I have a flex radiator hose already so it will be great to have a straight water neck like that.
advice ?
That won't fit. I have used them before on 360's and they are a lot bigger than that picture makes it look.
I have the part number from the seller but don't know how to check it. Somebody please tell me how to check if this one fit or not .
The part number on the thermostat is 180-L And the part Number for the water neck is #3666.
Thank you
Why do you need a different waterneck. Your intake shouldn't touch your neck and if it does it's not gonna harm anything unless it is making it pinch the pipe.
I need another water neck because the intake pipe bends the radiator hose. So there will not be enough coolant run through the hose to the radiator. I don't know how to get around this other than changing the water neck.
Any suggestion ?
Oh, I forgot to mension that I turboed my 4G64 and running with T3/T4. Thats why the intake pipe (turbo inlet) hits the radiator hose.
