will this turbo work
rha2506
35
Dec 18, 2003
guymon, Oklahoma
Hey I found a turbo off a 97 eclipse. Its the stock turbo.....will it work on my 95 rs ? also there is a turbo I'm lookin at off a 99 eclipse.....will it work ? I think they will but I just want to double check before i buy one.
they wont be a direct bolt on if thats what your asking, even if you buy the 4g63 exhaust manifold, it wont bolt up to your 420a motor... you're better off buying a whole kit.... but then again, i've never own'd a N/T, so making a DIY kit, this turbo might work, i just wanted to put in my 2 cents!
what do you mean just bolt on? I don't plan on just buying it and sticking it on my n/t...I was goin to get this stock turbo and buy the rest of the kit seperatly....I just want to know if it will fit on my 95 n/t.
I figure I'm gettin it for free...Mine as well not pass it up.....It might not be the greatest but thats all right...I can alwayz upgrade...I just want to know if I buy it....can I put it on my car and what all I need to get for my turbo to get the best outta it
yes it is the stock turbo on those...the T25......what do you mean ashmatic ?..............so...yes or no....will it do the job? and off of which car...the 99 or 97?
When he says asmatic, he means that after around 5k in rpms, the turbo does not make that much power and it begins to die down in psi.....
97-99 same turbo UNLESS one of thouse car's is an automatic because the auto's have a smaller turbo
YES it will work all you need is a manifold and oil lines
Also the T-25 has is water cooled so just plug those holes
Th e only reason it is water cooled is to keep oil temp. down so the oil won't coaked to the bearings or shaft, that can be avoided by changing the oil every 2500-3000 miles:dsm:
I am not sure, but if I were Hahn or Star, I would not sell the turbo kit without the turbo. I wouldn't care if you already had one. I'd sell you the kit minus the turbo for full price if you'd like.
Anyone know if Hahn or Star sells their kit without the turbos?
