Will this screw up my turbo?????
hippy
322
Jan 18, 2004
chtown,
Just bough ta 2 g with the head gasket gone and water is all through the oil everywheres. And there is a brand new turbo on it. T3/T4 Sc61. Will the water in the oil screw up the turbo?? Screw the bearings or seals?? IM hoping it wont hurt it. Thanks guys!
the turbo should be ok but if you let it get to hot the turbo might be bad. replace all the problems and get it fixed then see if the turbo is fine.
Oh sorry i guess i should have added this i bought the car like this and im planning not to drive it at all just taking out the 7 bolt and i got a built 6 bolt to go in it! There LOL DOes that make more sense and the guy that had it hardly drove it much after the headgasket went!! So im hoping that turbo should be ok!! What do you guys say?? It will be ok! I hope so!
if theres water in the oil, leak out all the oil and vaccuum any on ur engine or elsewhere, let it dry, then refill with new oil, water should be gone
