Will this PCV setup work
havlc2u
269
Feb 3, 2012
BFE, North Dakota
Hello
Just wondering if this PCV setup will work or if anyone has tried it this way?
The Lines from the Valve cover run to a T fitting then into the catch can.
Then out it runs to another T fitting then one to the intake before the turbo the other to the intake manifold.
This pic was edited from another post I should changed the caption I guess.
Thanks
[/URL][/IMG]
If you run it that way, you will need to install a check valve between the intake manifold and the T fitting. If you run it the way you have it drawn, you will be pressurizing the catch can and would also be losing boost into the intake pipe.
I run a similar setup except the out on my catch can only runs to the intake pipe which allows me to not have to run a check valve since the intake pipe never sees positive pressure.
Ok Thanks I will remove that T-Fitting. and run it just to the intake pipe.
In that case would I just cap off the fitting on the intake manifold?
So just breathing the cover to the intake pre turbo is enough by it self your saying. No need to have a check valve to manifold.
