Will the SCM6152R bolt up to my stock 2g manifold with the 4"SP cover?
You can run a 1G Non-turbo water pipe without needing to dent the pipe.
As well, the Mitsu flange (1G, 2G, Evo 3, etc.) cast manifold will have no problems.
I would also reccomend swapping over to a 1G cylinder head and thermostat assembly.
This turbo with the Mitsu flange will only support up to around 26psi and around 500whp. To obtain anything higher than this you will want to switch to a T3 or T4 housing and a manifold to match. The 2G MAF will also be a restriction above this boost level, and it is in your best interests to change over to a MAP sensor/AEM EMS setup with a 4" intake pipe/filter. Forced Performance makes an excellent 4" cast intake pipe and matching air filter for a reasonable price.
