Will opening mouth of bumper help with FMIC efficiency??
bsbllfit7
1,104
3
Feb 17, 2009
Salem, Oregon
hey everyone, i have a 2ga talon with the punishment racing fmic. The bumper on the talons done have a very large opening. Now my question is, if i was to cut the mouth to make it larger and show more of the IC will it be more efficient with its cooling capabilities?
More surface coming in direct contact with incoming air. Yes it will be able to cool better. Looks good too when its done right.
More surface area in contact with forced air would be more efficient. I would follow the advise from above and get a 2g eclipse front bumper if you are that concerned. If you do follow through and cut yours, I would suggest making ducting straight to the fmic so all available air is forced through it (if it has gaps between the ic and the cut bumper).
The only thing i cut out was the top black plastic, Looks good to me.
Just took out the dremel and cut it out, quick and easy.
Except for the road rashes on the bottom of the bumper, thinking of doing the HDR lip to cover them up.
Many big name people have ran 9's on a stock uncut bumper. The opening is more than enough. You can actually trap air if you cut the bumper in certain spots. It's not going to make a hell of a difference either way. It's more about your personal opinion on how it looks. I probably will be cutting mine a little bigger with the new 5"
It's all preference. I've never liked that wide open look the hipsters love so much. Just dying for attention..
i did it to my 2gb front bumper i cut out the inserts and i thought it helped with the efficiancy of keeping the turbo cooler.
    • The_Partout_Spot
    • The_Partout_Spot
  • For sale Garage clean out
    • 92GSXtacy
