will not shift into gear at ALL!!!? plz help :-/
Eclips3
Mar 30, 2004
cinti, Ohio
had problem with clutch not getting pressure to shift. wud go all the way to the floor. changed the steel brake line (something like that), that leads into the slave master cylinder for the clutch... caz it was kinked pretty good at the end of it where it screwed into the slave cylinder. ok bled that, now clutch has pressure, i thought good.. ok now itll work, i start it up, and it will NOT go into gear for the life of me!!! im totally stumped. idk but im thinking i need a new slave master cylinder or master cylinder. or i have no clue i need help and suggestions please. u think this is easy to fix and how much money wise .. please help!!!!!!!
You may just have to bleed it some more. I had to do mine like 10 times. Have someone push in the clutch while you look at the slave cylinder. when mine was real bad the rod didnt even move but the more I bled it the farther it threw.
just to let you all kno the outcome. it was the clutch master cylinder. replaced it now its perfect!
