headrec*
- 356
- 0
- Dec 9, 2002
Ogden,
Utah
Well to start I have ACT 2600/XACT flywheel, stainless steel line, new slave and newer master cylinder. I have had this setup for a year or so.
The other day my car started shifting a little "stiffer" so to speak. A little harder to get into gear. I checked my adjustment on the master cylinder rod and it was all the way out so I couldn't try to adjust it out any further. Well I thought it was just in my mind so I ignored it. Well tonight it was pretty much impossible to shift into any gear so I drove home without the clutch just rev matching it.
Well I got home and bled the system of air completely. Now the car won't even go into gear. If I start it in gear it just starts to roll. I checked to see if the slave was moving and it seemed to be moving normally with no problems. I checked for leaks in the master/slave and everything checked out.
I really don't know what else to check. Like I said I have had this setup for awhile so I don't think the flywheel step has anything to do with it. The slave is pushing on the fork very hard so I don't think the slave/master is out either. I mean I'm really confused on this.
Any help would be greatly appreciated. Thanks guys.
