Will my system slow me down much?
4geze63
891
3
Nov 18, 2003
edmonton,
I am soon going to be putting a 15" Power HX2, in a good sized ported box in my car.
Sub 45lbs
amp 12lbs
box 60 lbs
and my optima blue top which is allready in weighs 60 pounds, 30 more then a normal battery.
So thats 117lbs extra pounds in the hatch and 30lbs extra in the front.
Im a FWD and I only usually race from a roll, so would this extra weight make a noticable difference on how my car will pull when I step on it from a roll.
I figure if it was in the 1/4 I would lose around 1.5 tenths.
mods in profile if needed
a_scobel said:
I've always been told that it's one tenth for every 100 lbs.... :confused: :confused:
I've heard the same, but both figures are nonsense in my opinion. A simple equation will give you a better idea of what you stand to lose in terms of performance:
R = W/P
R = Ratio (Pounds per HP)
W = Weight
P = HP
W = 2791 + 180 = 2971 (Car + Driver)
P = 195
R = 15.24
Do the same for the new weight:
W = 2791 + 180 + 117 = 3088
P = 195
R = 15.84
Now, see what the HP loss is if you had the same weight:
15.84P = 2971
P = 187.56
So, on a stock car, it would be as though you lost approximate 7.44 HP at the crank.
my car is pretty fast anyways even with a 170 lb passenger so im not really worried about the overall speed, I just want to have a sub in my car :rolleyes:
