will MHI 16g wheels work in ebay 16g
someone should make a rebuild kit for these ebay turbos.:cool:
They're not designed to be rebuilt- they're built to be thrown away.
I know what parts are needed to rebuild one, but it takes the purchase of two parts kits to get the job done and unless you stock the parts it's literally cheaper and easier to buy a new eBay turbo and start with a clean slate.
Keep the housings, throw the central assembly away, buy a real oem mhi turbo, be happy that you have something that's quality and will last a very long time (if properly cared for).
how long did the ebay turbo last?
he put it on, burned a valve, rebuilt the motor, then didnt get it runing right yet and it started throwing oil. BUT, the oil had grit in it, because he had to go get his crank turned. The kid rebuilt the motor twice.
joe sobo said:
will you just do what justin told you? and throw that thing away ! tell casey to stick it up his OSCAR
Its KC, Casey is his cusion.
so what your saying is, it was junk the minute he put it on car with no miles?
