will bad o2 sensor affect performance?
A bad o2 will only affect closed loop operation. Ie, idle/off idle/cruise. Wide open throttle operation causes the ecu to go into "open loop" operation and the o2 is not looked at by the ecu. The ecu switches to a preprogrammed map. So, will it affect cruise operation? Yes. Wot operation? No.
Word.
Get a new one though, running too rich can wash your cylinder walls if it's excessive and too lean just generally isn't good.
Joel
