Will an SRS unit for 95-98 eclipse work properly in a 99 eclipse?
eclipse22188
May 23, 2009
Elizabeth, New Jersey
I recently got into a car accident where my airbags deployed, 95-98 eclipse have crash sensors in their fenders. For some reason I could not locate theses, and so I went to a dealership and spoke with both a mechanic and the parts manager. They informed me that the 99 eclipse doesn't have crash sensors in the fenders- but instead I would simply have to replace the SRS unit. Apparently there is in their words "A G sensor located under the armrest near the ecu". They then informed me that a new ecu would run me $530.00, and once the airbags deploy the SRS unit must be replaced.
Its raining today so I can't go out and check my car for the part #, so I figured I would ask - Do you think and SRS unit from a another 2g eclipse would work properly for my 1999 eclipse? Im sure I could find a used one for alot less than $530 LOL
thanks in advance.:thumb:
I'm not sure about the sensors in the bumper, I did have to totally disassembled mine to custom install my FMIC and I did not see them infront or behind the safety bumper.
When I replaced my ECU (voltage controller for alternator was shot and is located in the ECU for N/T's) I did find a place that made it totally easy and gave me an updated and rebuilt ECU w/ a lifetime warrenty and free shipping for $199: LINK
ECU = Engine Control Unit
You should say Air Bag Computer or you may confuse people.
From what I've seen at the junkyards all the 2G airbag systems look the same, but I haven't compared part numbers.
Make sure your battery is disconnected when replacing the computer, or working on any part of the airbag system.
The SRS unit will work even though the 99 eclipse has a different airbag system from early 2g eclipses?
ok so basically any srs ecu from a 96+ 2g should work- thanks alot man
I found a 99 srs ecu on ebay undeployed for $160 (w/s) so thats already a lot cheaper than $530.00...im going to go looking tomorrow tho- thanks again for the help
i got a driver airbag already and i should be getting the passenger by the end of the week...its been a major pain trying to get the min black i keep finding grey LOL.... thanks tho
  • Wanted 6 bolt NT water pipe
    • chrisman287
