Will a t3 t4 turbo fit?
Is your manifold stock?
My HX40 is mounted on a stock manifold! It all depends on which exhaust housing you can get but the most common turbos are 16g, 18g, and the 20g. You can get just about any turbo you want. Just remenber the stock housing at some point well hold your turbo back.
The better ? would be want are your HP goals? And what do you plan on doing with the car(drag, road, street)?
The first question you should be asking is: Do I have enough supporting modifications, datalogging ability, and tuning ability to be able to upgrade my turbo?
If the answer to this question is no, then you have a ways to go before asking about T3/T4 turbos, or anything bigger than a 14b.
