will a stock clutch work?
technical_pawn
67
Apr 9, 2011
mason, Ohio
I'm wondering if I need more than a stock clutch. I'm rebuilding the engine right now completely with stock internals. I'm running a six bolt with
NPR turbo pistons and rings
Big 1g rods
Apr mains and head studs
Mhi evoIII 16g
660's-880cc injectors (haven't bought yet)
Mitsubishi head gasket
Stock crank
lighten flywheel (11.5 lbs)
catch can
FMIC
greddy type s
Dsmlink v3
255 fuel pump
AFPR
3g revised lifters
I have a new EXEDY OE CLUTCH KIT for my car. I'm putting everything back together in the next two weeks. I'm just wondering if I need to get a new clutch before I put everything in the shell.
yes I am. I wanted to know if the mod list will be to much for a stock clutch set up. I'd rather not have to pull it apart again in two or three weeks because the clutch slips and wont hold up to the power.
With that setup, you could start to push enough power to slip a stock clutch. I would say go with a ACT 2600 and do it right the first time.
