2G Will a ACT 600160 fit a 2G NA?
Myristica
58
Jun 26, 2011
Antwerp, Europe
Ive got a new ACT flywheel from a friend here. But will it fit a 2G NA?
Accordingly to there site it wont. But the one for the 2G will only work combined with pressure plate and disk.
I dont see why this would not fit.
This is the flywheel.
http://www.advancedclutch.com/600160
A 2G NA, as in a 420A? Nope.
The 420A has 8 flywheel bolts; this flywheel is for a 7-bolt 4G6# engine.
He has the euro model 2g n/t which is a 7 bolt n/a 4g63. The flywheel should work, but there might be some bellhousing clearence issues depending on what trans your car uses. If it uses the same trans as the spyder and galant than the turbo flywheel will work, but there is a part of the casting that has to be ground down for it to not rub in one spot. It looks like with the aftermarket the spot that rubs is further in so it shouldn't be an issue.
The 600160 is a 7b AWD flywheel, the 4G63 non-turbo FWD cannot use the flywheel because the diameter and tooth count won't fit your application. The 600165 flywheel is what you would need to work properly with this specific setup, then any turbo clutch.
  • For sale 4G63 NEW Stop Tech Drilled And Slotted Rotors
    New Stop Tech Drilled & Slotted Rotors $70 + shipping and paypal fees* FITS * Eclipse GST...
  • For sale 2g 2G GSX/GST Manual Transmission Steel & Poly Mount
    2G GSX/GST Manual Transmission Mount (Steel & Poly) $45 + shipping and paypal feesYou must be...
    • sanmantsi72
    • El_marto
  • For sale 1G DSM 4G63 PARTS
    • The_Partout_Spot
