will 1gb talon fit on 1gb eclipse
Isnt
39
Nov 11, 2013
San Diego, California
Will the tail lights of a 1gb talon fit a 1gb eclipse with no modification? also what about the bumper? if no tail lights, at least the bumper? Thanks let me know :)
Short answer... Yes
1st your wrong. You will have to slightly modify a bracket that is welded under the eclipse bumper. Also you will need to modify the wiring to the rear lights if not your yellow amber turn signals on the talon bumper will light up when you press the brake and flash fast as if you have a bulb out.
So... Short Answer... Yes ROFL
Wiring modifications are not necessary, under the radio there is a black box used for the eclipse/laser taillights. The talon just has a little relay with a wiring pigtail, you will need to find this and swap out the big black box with the relay in order to have your taillights and blinkers work normally.
