madman
- 472
- 3
- Oct 9, 2003
Kansas City,
Missouri
So I had some engine work done on the car ( valve job ) and had the mechanic install my new turbo, manifold, etc.... and I'm looking at how he hooked up the MBC and I've never seen it done this way.
The first pic is from Defiant's tech article ( hope you don't mind me using it ) which shows how a MBC is normally installed.
The second pic is how my mechanic is installing it. He says that this will actually keep a larger turbo ( mine is a 50 trim ) from creeping because of the vaccum leak from the side nipple being left open / uncapped.
Has anyone of seen this or heard of this?
I don't get the car back till Monday and then I drive out of town. I should be able to adjust the boost pressure and see if this actually works.
