GeneralChaos
- 366
- 1
- Feb 13, 2004
Belleville,
Michigan
So i ordered a cheapo air filter + maf adapter ( http://cgi.ebay.com/ebaymotors/ws/e...&item=7955475666&rd=1&sspagename=STRK:MEWN:IT ) for my talon a while ago and decided to just put it on today since itd only take a minute.
so I get the air box out and of coarse the bolts that went into the maf arent removable.... no big deal, went and spent 50 cents on some new ones.
I get back home, put the maf adapter on the maf, attach the bottom silver part with the coupler on it to the maf plate, but heres my issue:
Usually that plate is attached to the filter itself...on this it isnt. where it would connect there is a hard plastic substance. Is this just plastic or is it glue? im thinking its either hot glue and I can heat it up and it will hold itself together, or its just plastic and I put some industrial strength crap on there so it cant go anwhere.
Go figure I get problems on such a simple install
suggestions?
suggestions?
so the maf adapter plate has a substance going around the circular part you attach your filter too? I'm alittle confused with your post, Is this substance sticky if it is, I would personally clean that crap off because that would suck to have it get heated up and the possiblity to get sucked into your turbo. Ifyou can get another picture of this we may be able to help alittle better but I would clean any sticky stuff off of it because it should just be a piece of metal with nothing on it, if I'm readin this right.
