wierd door alarm and car alarm
zachwilliams02
183
Dec 30, 2012
marietta, New York
Ok wo I've owned my talon for about four or five months. The entire time I've owned it the door alarm has never worked and neither did the courtesy lights. Well today I got out of my car and the lights were all on and so was the door alarm. Then when I locked it and shut the door I looked at the dash and saw a green light that said security. Well I cake back later and unlocked my car from the passenger door because ky driver side handle is broken. When i opened the door the alarm started to go off..... I had no idea I even had an alarm and I don't even have a key for the drivedoor. So what should I do to fix my doors or the alarm or whatever changed
Have you tried finding and pulling the fuse to the alarm? If horn lights ect ect ect is on the same fuse, try removing the relay.. I'm not much on a 2g but that would be the steps I would take..
Ok and weirdly enough my horn doesnt even work so now I know that the problem is in the steering wheel. I did research and the switch on the inside of my doorhandle may have come off
