wierd clutch problem???
howdeyjake
89
Oct 28, 2005
prairie village, Kansas
Ok, i was coming home from work yesterday, sitting in 3rd gear at about 2000 rpm and for some reason or another, i decided to floor it, release the petal, floor it, release the petal etc...and did that about 5 times. I shifted into neutral and then stopped at the stop sign. I put it in first then released the clutch. As soon as my car started moving a HOORRIBLE screaching/grinding came from my clutch when it was slipping(when it is fully engaged it doesn't squeek/grind). I got home in 1st gear afrade to shift incase I couldn't get it back in gear. I got home from school today and got in my, started it, and put it in reverse and reversed up our hill with no problems, it engaged fine. At the top of our street I put it in gear and preceded to go down the hill. The screeching resumed and it was the same thing as last night. It does it in every gear up to 3rd(the last gear I could get to while going down my street). I went up and down a couple times then parked my car. I pushed my clutch in and the screeching/grinding started again while I had my e-break on and wasn't moving, but it was a much less severe squeeking/grinding. So now when I push my clutch in the screaching/grinding starts up untill I let off the clutch again. Any clue what could be going wrong with my clutch??? ANY help at all is appreciated, I just need to know where to start with this problem.
Thanks in advance!,
Jake
Congrats on bending the fingers on your pressure plate!!! The almost exact same thing happenned to me while driving home, decided out of no where to beat on the drivetrain .... when you press/release to dump your clutch like you described it heats up the metal of your pressure plate and weakens it temporaraly. It doesn't catch up with you untill you hit the light because the metal would have been stuck "bent" as your drivetrain slowed and clutch assembly cooled. The most commen way of doing this is actually slowing down quickly from VERY high speeds (which I can also verify through experience) LOL ... but my best guess would be replascing your pressure plate (and while your in there you might as well drop in a new clutch (or modular kit.. I can't remember if GST's are or not) and throw out bearing
:confused:
He was describing getting on and off the gas several times, not shifting, for one. Two, even if you shifted 30 times within 5 minutes or less, it's not going to 'weaken' the fingers due to heat. Three, decelerating, doesn't do this either.
Like a previous poster said, sounds like a TOB is bad.
Morphius said:
:confused:
1. Thats the exact reason why I think the throw out bearing is fine. He wasn't shifting, the throw out bearing shouldn't have made contact with the pressure plate with the clutch fully out.
2. He wasn't shifting, If he was I would have suspectd the TOB first
3. I didn't say decelerating In general, I said decelerating from high speeds. It is also a proven fact that this DOES lead to damage to the pressure plate's fingers, It could even be a mild warp that would do this, but throw out bearings usually dont stop working and start screaching instantly..... regardless of weather or not howdeyjake did stop quick or not, I thought I would throw that up in the air.
4. As long as the tranny is out to replace the throw out bearing, unless the clutch is BRAND NEW he would be stupid not to replace clutch components.... so either way I would highly recommend both a TOB, PP and clutch disk
He describes the noise as happening when he disengages the clutch, not when the clutch is fully engaged.
Please reread his post.
Please post your info on relation of decelerating from high speeds to PP finger damage.
Given what he describes, a TOB should be enough, but like you suggest, it might not be a bad idea to do the clutch.
You may have meant one thing and wrote another but, here is a clarification:
howdeyjake said:
....sitting in 3rd gear at about 2000 rpm and for some reason or another, i decided to floor it, release the petal, floor it, release the petal etc...and did that about 5 times. I shifted into neutral and then stopped at the stop sign. I put it in first then released the clutch. As soon as my car started moving a HOORRIBLE screaching/grinding came from my clutch when it was slipping(when it is fully engaged it doesn't squeek/grind).
howdeyjake said:
..... I pushed my clutch in and the screeching/grinding started again while I had my e-break on and wasn't moving, but it was a much less severe squeeking/grinding. So now when I push my clutch in the screaching/grinding starts up untill I let off the clutch again.
Cleary states he was getting on and off the gas. Came to a light. Disengaged the clutch and the noise started. Tried driving the car later, again, issues arrises when clutch is disengaged.
96gsdsm said:
.... when you press/release to dump your clutch like you described it heats up the metal of your pressure plate and weakens it temporaraly. It doesn't catch up with you untill you hit the light .....
To me, you are stating he was actuating the clutch when in reality, he was only acutating the gas pedal.
Thus, the reason I responded like this:
Do you follow?
ok, you all have conviced me. TOB it is then. :thumb: sorry for the confusion.
Ok, you guys say I should replace my clutch why I am at it...should I still do that??? Also exactly HOW hard is it to replace a throw out bearing??? And it happened why I was just flooring it and then letting off, doing that about 5-6 times then shifting it into neutral, and noticing the horrible dolphing like screeching at the light when I was engaging the clutch then it stopped when it fully engaged. Now it does it just when I push the clutch in in general, and gets much more extream when I try to engage the clutch. I guess my next step is to figure figure out if I need JUST a new TOB, or a new clutch also, and to find out how hard one of these is to put in. I REALLY appreciate the help guys!! I would have had to spend HUNDREDS! taking this to a shop to repair, when I could repair it myself, and have fun learning how to repair it. So far I have replaced the alternator, i'm replacing starter tommrrow, then whatever I have to repair on this pry next week. Next thing to do is make it fast and put a new ebay intercooler on it!!
Thanks for the help guys!,
Jake
I would highly recommend putting in a new clutch kit, which would include throw out bearing, pressure plate, and clutch itself ..... unless your clutch has ridiculously low miles on it.....
It's just the fact that the clutch, pressure plate and throw out bearing are all extremely easy to install. The thing that makes the job so difficult is that you have to remove the entire tranny and axles and such to access them.
I bought my whole assembly for $200 shipped on e-bay from a seller named ezclutch and installed it myself a few months ago. Never had a complaint about it EVER, and it's suppossed to hold 300-400 HP. Me and a buddy installed it in about 6-7 hours and it was both of our first times installing a clutch.
If you do install it yourself plan on having your Haynes manual handy and disassembling alot of odds and ends to get to it. It also helps if you jack up your car as high as possible.
oook thanks man...I think i'm ordering my clutch tonight. I have a buddy of mine who's brother is going through college studying to be a mechanic, and hopefully he should be able to help me do my clutch. Even he aggreed it would be the TOB so I guess a new clutch kit it is! Will update when job is complete.
Thanks for the help!!!
Should be perfectly sufficient! You're FWD so you're not going to put as much force on it as some of these AWD 4g guys
AWSOME! You don't think there will be any chatter or anything??? As a rule I don't race my car and I never take it to the drag strip so this would be strictly for just messing around on the streets and to work and back and such. So you guys think this will work for my setup if i'm not really dragging??
You might have rough engagement seeing it's a 6 puck, but it should be perfectly streetable, it just might take a week to get used to as opposed to a stock clutch :thumb:
Cool. I alreaghty had a racing clutch so it shouldn't be THAT big of a change. Thanks for all the help and I will update later when I get it installed.
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale 2g 2G 7 Bolt Cylinder Head
    2G 7 Bolt Cylinder Head $250 + shipping & paypal fees* deck surface measured measured at 5.20...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
