Wierd starting problem
stevetalon
135
Aug 1, 2007
Frederick, Colorado
I have been having this starting problem that just started happening. I was driving around the other day and turned the car off and started it many times without a problem. Then i park my car and go to start it and everything has power and i turn it to start and everything shuts off and my battery has no juice:confused:
Battery was checked at autozone and is good
starter was checked and is good
So i tow it home and charge the battery and the starter will not engage no clicking from the solenoid but the fuel pump is turning on.
Today i go to start it with like 12.5 volts and it starts fine and my alternator is charging the battery. I pull it in my garage and turn it off and try to start it with good volts and everything turns off and my battery is dead. Is this caused by a short?:confused:
Ok I just replaced the power cable that was going to the starter. Now when it gets hot the battery doesn't just die anymore but all i get is the mpi relay click once every time i try to start it . I went to checkers and they told me my battery or alternator is bad and my alternator relay was really hot. Is it just the relay:confused:
Ill get the alternator checked tomarrow
