ECMlink Wideband got disconnected
AlexGsxCummins
395
38
May 31, 2014
Bremerton, Washington
Alright, my wideband yellow wire that goes too the white wire in the ecu got ripped off, my car was running like crap trying to figure it out. I finally found that and i had the car off hooked it back up then when i started the car the idle was jumping from 1k-2k rpm and it just kept pulsing so i then removed the wire and the car did the same thing? Not sure what to do...
God, this is turning into a nightmare and it sucks vecause I need this to drive. Okay so when i was trying to figure out why my car was not running right, i put on a stock 2g coil (it had a evo coil) and i bought a new power transistor, so now that i found out my wideband was disconnected and i had this surge I figured I would backtrack and i put the old evo coil back on, then only 3 cylinder have spark... It was running fine with no surge it just had a dead cylinder. I guess I'll throw the old power transistor back on? I need some help!
I finally think i fixed it I put the old power transistor back on and it seems to be running good. I hate this afx wideband thats next on my list to get. It sits at 16 at idle but it matches when i give it throttle. But i just hate the display and how big it is. I'm going to test drive it now.
