wideband and fuel trims
GalantGst
109
Jan 7, 2005
Elmhurst, New York
i have a wideband and im tuned for around 14-15 cruising and 11 under boost.
my fuel trims are at 139.9 percent thou i dont understand why.
I have the narrow band out put hooked up to the ecu and the ecu is def getting o2 voltages.
or u think i should just come more fuel till the fuel trims stabalize between 100%?
Your computer is always trying to keep itself around 14-15:1 at cruising speeds. You need to add some fuel to your low settings to bring it back to 100%. What are your settings at now?
i have a 2g maf and 550 cc injectors(stock pump)
its at -5 cruising and bosoting is + 8
my question is at idle is the o2 supposed tobe stoick(14.7)
i had it at lean before now i have it to stoich and my fuel trims are good around 100-105
