1Gina2G
- 810
- 2
- May 6, 2011
Beaufort,
South Carolina
Okay so I've taken off my water pump pulleys twice now, I don't understand the deal. I've used these same pulleys, which are in good conditon, including the crank pulley. Altnerator pulley is also in good shape, and inline with the crank pulley.
the smaller water pump pulley also lines up with the powersterring, being dished in towards the engine. The bigger outer pulley was also dished in towards the engine but the pulley appeared to be wobbling. Flipped it, to dish outwards, and now the alternator belt will not stay in the pulleys in line, even though the pulleys are not oily.
Looking at the timing from above, it looks like the outer pulley is just a tad more outwards than the alternator/crank, so the belt attempts to move towards the engine side, riding on the edge of the water pulley...
I've compared online even, to be sure I have the correct pulleys, and they look the same, and have worked before.... is it possibly because these pulleys are 7 bolt? on a 6 bolt water pump?
