Why is my tach needle jumping [Merged 9-9] tachometer jump
Birt96gst
117
4
Aug 28, 2005
black diamond, Washington
While I'm driving my tach will start to jump around and my car will start jolt real bad
need help.
Would a CAS thats shorting out cause this or a cloged fuel filter or maybe just maye a cracked intake manifold?
need help fast need my car to get to work tomarrow
THANK YOU
Many possible causes including a bad gauge but we covered the typical cases. A non-90 ECU and a missing or defective noise filter. Since your running a SIMM where is the coil pack located? It is a 90 versions, correct.
Has this always been going on or a new problem?
I am running a 90' coil pack and ever since I got the SMIM and DSM Link this has been happening. I want to find the source of this problem, but I'm probably going to install the Dynatek ARC-2 CDI box a long with an aftermarket tachometer. So as long as this doesn't interfere with my ECU or tuning I'll just leave as is.
