Why is it so slow???
u6t9
430
Jan 19, 2004
Kearney, Nebraska
hey,
so my friend just put a evo III 16G on, 650cc injectors, fuel pump, AFPR and AFC-II. oh and intake and 3" turbo back exhaust. boost is at 20 PSI.
we took it to the track today and his best time (with devilsperm driving!!!) was 14.6 ....??? :confused: we thought it would run like a 13.5
anybody have any insight as to why it is so slow?
thanks for the help guys!
How is the tune on it? 20psi won't mean much if you're running 8:1 AFR. You didn't mention having a datalogger- you'll need one with the AFC in order to dial it in correctly. Or you can use a digital voltmeter on your o2 sensor. RRE has a really good write-up on this:
http://www.roadraceengineering.com/newafc.htm
and
http://www.roadraceengineering.com/newafcsetting.htm
You should also check for boost leaks, and make sure your IC has time to cool down completely between runs. You didn't mention a front-mount, and 20psi is pretty high for the stock sidemount. The evo III 16g is rated at 550cfm, which I'm pretty sure is higher than the stock sidemount is rated at. I couldn't readily find the flow rating on the stock sidemount, but you get the idea- at 20psi the stock sidemount will heatsoak very quickly, most likely after one run.
Good luck, hope this helps.
that's what i kept telling him that he was probobly heat soaking it. we do have a datalogger, he's running palm'n'stein and we got the timing as close to 20 as we could.
i'll tell him to check out those links, (and get a fmic, again...) then we'll tune it more and see what happens. any other ideas???
thanks guys!
