Why is it reading knock so high?
supermanvick
72
Apr 24, 2006
Richlands, North Carolina
When i start up my car my S-AFC II will read a knock of 50 then slowly rise to about 190 can anyone tell me what the problem is. Im running 550cc injectors on a small 16g and thats pretty much it.
First of all how much boost are you running. I would run about 10spi until you get the proper fuel. Depending on fuel it can cause knock problems. If you said it ran fine before and its not now, you have a problem. How long have you been running your setup?
Disconnect the knock wire on the AFC completely too. I've heard if it's hooked up it can affect the way the ecu reads knock sums and possibly damage the engine. If the ECU is getting inaccurate knock sums the timing will be off and it could cause detonation.
