Whos running Bosch 044 Fuel Pump?
garage16
133
Oct 4, 2008
toronto,
Just like to know who is running one and whats the max power its good for before grabbing a 2nd pump
The Bosch 044 is only a 200LPH pump, and is good for 500-550hp
The Walbro 255 is a 255LPH pump, and is good for 500-550hp
LPH = liters per hour
GPH = gallons per hour
1 Gallon = 3.78 Liters
You must compare your LPH with PSI. The 044 flows 300 @ 50psi, and 200 @ 70psi (compared to mixed results from different sites)
The 044 has been compared to the Walbro High Flow 255 so how can it be better than the A1000 without the Walbro 255 being compared equally?
Call Aeromotive and ask them how much their flows at 72-73 PSI/5 bar. I can tell you -nothing. This is a pump for NA motors. For turbocharged cars is important how much the pump flows under boost. Before I wanted to buy A-1000 my self, but after I spoke with Aeromotivt tech, I called it off. It is a glorified Wallbro.If you want a good flowing pump, for turbo car, check Magnafuel:
:MagnaFuel MP-4301 - MagnaFuel ProTuner 625 Series In-Line Fuel Pumps - summitracing.com
See this thing up to 120 PSI. And it can be had for around $ 400.
  • Wanted 6 bolt NT water pipe
    • chrisman287
