Who's Runnig 3 Electric fans
STGGSX
Mar 2, 2006
Bountiful, Utah
I wanted to know if there is anyone that is running 2 puller fans and i pusher fan. and if so how does the car run. I have done everything to make my car colder "I live were it is 115 degrees" and h ave added 2 SBR 12" electric fans and also a 180 degree Thermo and the car will not run any colder than 215 and around that temp. so i wanted to add a 3rd electric fan on the front of the condensor to help pull some air in. This all started after i put my Greddy FMIC on.
What i did to get mine to finally cool down was to make an air dam under the car that forces air into the radiator
What coolant mix are you using 50/50? And what brand of tstat? I would use a mitsu over a stant, I heard reports of the stant not opening @ the right temp.
