Fans
2tsi_auto
Jan 27, 2006
Fargo, North Dakota
Do you have to keep both of your fans on your car or can you eliminate one of them.
you can remove your a/c fan if you don't use your air conditioning.
When your car reaches the temp which requires a fan to cool, only one fan activates.
Further, just pop the hood and let your car idle until the fan kicks on to regulate coolant control, and see which one is operating. Then, turn your a/c on and see the other operate.
playitlouddsm said:
A/C fan is drivers side, on a 2g at least. Mine is removed b/c of external wg.
1g also. Mine is off also, due to RnR 3" dp. No problems yet, & it sees track days and the a/c works fine (I do have a Fluidyne rad. though;) )
Yup drivers side. So its possible to have a/c with no fan? I really need a/c living in Ga and i was considering getting rid of my external wastegate for a/c.
