white smoke coming out of driver side of motor?
theboss88
71
Nov 8, 2008
allentown, Pennsylvania
i got white smoke coming out of the driver side of the motor
the belt would squeel for a while but would go away after car would start
but now the belt doesnt squeel instead white smoke pours out of the side
heres a video:
<embed width="448" height="361" type="application/x-shockwave-flash" wmode="transparent" src="http://i250.photobucket.com/player.swf?file=http://vid250.photobucket.com/albums/gg276/ryanmock_20078/VID00003.flv">
look at the video the power sterring belt was squeeling then just stop but i tryed drving the car while it was misfirein and the its like something popped and white smoke started to come out of the engine bay
well its def coolant it smells like it, and the smoke is coming out of the area of the head gasket. the car is stock
anyone ever blow their head gasket
ok cause i checked the oil there is no coolant mixed in with the oil
and there is no oil leaking just coolant
im think that a hose popped of and everytime the water pump spins as puff of smoke comes out
if you look at the water pump on the car, there is a round pressed in metal freeze out plug on the water pump. this may have popped out as it did on my car with only 23p.s.i of boost.
it may be hard to see, cause it would be located behind the altenator
yea theres coolant but the smoke really puffs out like crazy and a mist of coolant comes out with it
would a blown water pump gasket do this?
its not leakin any oil while it sitting it just shoots it out why its running?
You're going to need a new headgasket and a new water pump in the least. The squealing was caused by the pump. Either the pump failed first and the engine overheated, or the headgasket failed leading to the coolant system being pressurized by the cylinders and resisting the belt movement. If the block was not properly surfaced before you put the head on, the leaky gasket probably broke the pump. If the block was prepped correctly, then the pump failure probably led to overheating, head warpage and a blown headgasket.
Either way its the same parts to replace.
the car sounds like a piston going non stop
and the smoke seems to be coming from below the head gasket line like toward the crank shaft
If the engine never overheated, and the pump or it's gasket is the culprit, you won't have to replace the headgasket. One way to find the coolant leak is to drain and then pressurize the system with a compressor and spray soapy water near where you suspect a leak(make sure the engine is plenty cool before trying this). Sorta like doing a boost leak test on the cooling system. Make sure you open the oil fill cap and listen when you pressurize the coolant system, if there are any air leaks there, the HG will definitely have to be replaced. A compression test is also in order to verify the headgasket is still sealing, particularly pay attention to how cylinder #1's results compare to the rest.
the car never over heated
the car was misfireing then when i tried to driv ethe car with the misfire the white smoke started pouring from under the hood on the belt side
