white face gauges help
i know there used to be a write-up on VFAQ. you need to remove the cluster and slide them over. The proper way is to solder the power to the gauges to the back og the cluster where the OEM supply is, its less wire and cleaner.
It is easy on the tach and the speedo but were the oil press, and boost gauge is to close to just slide it under and it is the same way on the other side were the gas / water temp is, and i was just trying to find out how to do the small gauges...
