which wires were these and were they needed??
codeofdastreets
505
3
Sep 25, 2008
dunedin, Florida
I have the 6 pin fan harness, green/black go to the rad sensor, blue black go to power for fan, other 2 are cut and stripped.. any idea were they go and were they needed?
The stock 1g radiator fan plug, plug A-40, only has 4 wires:
  • Blue/Black - Ground (fan motor)
  • Blue Red - Fan relay (fan motor)
  • Green/Black - Ignition switch (thermo sensor)
  • Black - A/C fan relay (thermo sensor)
Looking at the wiring diagram (as my A/C has long been removed), even the a/c condenser fan motor only has a 4 wire plug too, plug A-32
Best guess is its not stock, and the two removed are for your accessory fan (ac fan). a 1g should have a second connector on the core support near the PS pump.
Ok, on the Galant i believe u need to use all 6 wires. Is this wire for a 1g,or gvr4?
for the gvr4
posted 04/25/10 10:03 PM
Check out the circuit diagrams located in the factory service manual for the Turbo fan harness. Actually, here it is, along with the wire color chart:
Connector A-29 is the one you're interested in. It has 6 pins. From the diagram, you can see the pin designations as follows:
Pin 1--------Blue{L}-----------------From Fan LOW relay to Resistor
Pin 2--------Green&Black{GB}---------From Fan LOW relay trigger to Thermosensor
Pin 3--------Blue&Black{LB}----------From subfuse panel to Fan
Pin 4--------Blue&White{LW}----------From Fan Relays to Fan
Pin 5--------Black{B}----------------From Thermosensor to GROUND
Pin 6--------Black{B}----------------From Resistor to GROUND
Check this thread out off gvr4.org
http://www.galantvr4.org/ubbthreads/showflat.php?Number=893267&Main=892965
