which wire is airflow for safc install?
terminaltsi
309
Dec 16, 2001
louisville, Kentucky
well, i have the wiring ecu diagram, but the wire that is supposed to be for airflow isn't showing any karman hz readings when i have it wired up...
it's a white wire, the 7th over from the left if you are looking at the back of the plug (wire side). is the apexi diagram wrong?
this pic is for a 2g -- but it still shows what colors on the AFC goto what.
pink to the ECU and orange to the AIR flow signal.
great, that's exactly what i needed. if i had not been thinking about a woman at the time, i would have realized i should have counted over 3 pinholes, not 3 wires, which would have put me on the correct wire.
thanks.
