Which way to go 2.0 or 2.3?
You did'nt include prices for valve guide install, valve seat cutting, or any gaskets. Basically everyone on here is biased towards whatever they are using (no big surprise). I have seen a person recommend something hole hearted and then turn around a year later and tell the person not to ever use that same thing, not because they had a bad experience with it, but because they found a new "hotter" ticket that someone that they look up to is using. The 2.0 can probably be made to do whatever a person wants with different compression ratios etc, and as for durability we know that Shep and Brent Rau use a stock bore 4g63, so they are pretty well proven. This does'nt mean that the stroker is'nt well proven either, alot of people love them and have real good luck with them too, but we know more about the 2.0 since they have been well traveled. Good luck with it though, and keep an open mind and do twice as much research as you already have. I would suggest calling a couple of non biased shops for opinions, to be honest thats the only way that you will get the best non biased answer. Measure twice, cut once!
