Which Walbro?
Moparbishi
112
Sep 15, 2007
Fremont, Nebraska
I am turboing a buddies N/T eclipse. Just trying to gathers parts for him. Is the the walbro 255 gona be the same for the turbo eclipse and the N/T. If not could someone give me a link to a N/T walbro 255 please. What part number for spark plugs should I go with. I would imagine I should change em out for atleast a step colder. Thanks for the help, im NT retarded
I think the NT and Turbo (non AWD) pumps are the same, dont quote me though. But you can get them on ebay, or Extreme PSI.com. As far as the spark plugs go the base NGK number is BKR6ES, an for boost levels up to 1-12lbs. use BKR7ES. Now if your gonna go anymore than 15lbs use these plugs, BKR8EIX. They are 2 steps colder, and when i used them in my 420a, ill tell ya 27lbs of boost never felt so damn good.:hellyeah:
All Walbro 255lph HP fuel pumps are the same (they all have the part number GSS341). You can buy the fuel pump alone:
EXTREME PSI : Your #1 Source for In Stock Performance Parts - Walbro 255 LPH High Pressure : GSS341 (Pump Only)
Or buy it as a part of a kit:
EXTREME PSI : Your #1 Source for In Stock Performance Parts - Walbro 255 HP with Install Kit: Mitsubishi Eclipse 95-99 Turbo
You shouldn't really need the kit as you can re-use the parts from the original fuel pump assembly.
