2G Which turbo should I port
da kang3
190
Mar 26, 2005
ft hood, Texas
okay im think of either porting my stock t25 or buying just the turbo housings of either a 14b or b16g and having them rebuilt and ported. if im trying to stay on stock internals and want to get my car to low 13's and be decently fast on the street. which would be a better option for me. oh and im lookin to make somewhere between 350-375whp on my 95 gsx. right now i just have 3"turbo back exhaust and high flow cat. upgradin my clutch to a spec stage 3 and may be gettin an apexi bov. any help or suggestions would be appreciated thanks
To make that kind of power you will need a 20G or bigger turbo on pump gas and a FMIC and fuel mods.
With a 16G and 550s and cams and a big dejon side mount i was just under 300 whp.
I would do a 50 trim or V trim with 720s and FMIC you will be close to 400* then.
*results may vary. proper tuning required :thumb:
Definitly don't waste any time on the T-25, it will get you no where near those goals.
Also you should be able to run 12's on a 16g and the stock internals quite easily, with the proper supporting mods of course.
