Which Sway Bar?
flipnoy213
145
Mar 23, 2004
Stockton, California
What the difference/ and which do i need?
Mitsubishi 95-99 Eclipse (All Models, With OE Rear Sway Bar) Suspension Techniques Anti-Sway Bar (Front & Rear, Part#52212)
Mitsubishi 95-99 Eclipse (All Models, Without OE Rear Sway Bar) Suspension Techniques Anti-Sway Bar (Front & Rear, Part#52212+55365)
Look and see if you have a rear sway bar... If you do then you need this one...
If you don't you need this one...
I believe the difference is one comes with mounts & hardware and the other doesn't
flipnoy213 said:
what? :confused: Some eclipse doesn't come with rear sway bars????
Only the RS.
One other thing to take into consideration is fitment. I've read a few posts about fitment problems with the Suspension Techniques sway bars and some aftermarket exhaust systems (if you have one or plan on getting one in the future).
Module Unknown said:
Sure are. Check out the RMDSM bars.
http://www.rernetworking.com/rmdsm/stabilizerbars.html
http://www.machv.com/rmracswaybar1.html
I have the RMDSM bars on my car with a 3" Thermal exhaust. No fitment issues.
Agreed. I have these on my AWD (front and rear) and they are great...no fitment issue either....not sure of the difference b/c i did the springs and shocks at the same time so can't tell what changed more...but it is worth it...especially after seeing how rusted the linkage was on the stockers. :thumb:
What companies make Sway bars for our cars beside ST and RMDSM? And which do you guys recommend to buy? for my GST
