Which Sway Bar is better? ST or RM?
Z32
45
Sep 14, 2005
Chicopee, Massachusetts
Hey there, after i installed front control arm and sway bar bushings my car's been understeering too much, so Ive decided to buy a rear sway bar along with rear suspension bushings. So I have 2 choices Suspension Techniques sway bar or RM sway bar, which in your opinion is better? After some research I found that RM sway bar is 15/16" thick and is more expensive then ST, and ST sway bar is 1" thick yet cheaper then RM. I need your input. Thanks.
Yeah, understeer is a biotch on our DSM AWDs. I have the Suspension Techniques sway bar kit, both front and rear, and the ES bushings and ES adjustable end links, they are great, you can adjust for over and understeer easily.... and they do thier job with the suspension part, they are worth every penny, and that is a lot of em... and just a question, why didnt you buy both at the same time? What brand is in the front? :talon:
Where did you get your endlinks? I tried to put a Suspension Techniques rear sway bar on my 1G yesterday, and sheared one of my factory endlinks in the process.
*EDIT*
I thought you had a 1G like the topic creator, so nevermind.
