Which Spark plugs to use with my application?, help quick!
Spoolio
730
10
Sep 3, 2003
Port Charlotte, Florida
ok, if you look at my vehicle profile you will see what i am running, ontop of that 17-18psi, what should i be running for a spark plug?, i have currently bpr6es., i dont think that is correct. someone help me out quick in the next 10min cause im going to ricerzone to pick up some fluids.
I think youre running the correct plugs. I hear NGK is the way to go with these cars. I've had good RELIABLE luck with them as well.
I'm not sure at what psi(i thought 24ish)you should be running to move to one step colder plug.
Let's not get nuts. 6ES or 7ES gapped to .028 will work fine. It's not like 18psi is a killer amount of boost and you'd see a big difference between them. I've run stock heat range Autolite 63's to 26psi without a problem.
Hope that helps,
Andy
