Which mod should come first?
GSTurbo92
Nov 6, 2003
I am upgrading the fuel system on my 1g eclipse gst and i need to know which should come first fuel injectors or fuel pump? Will the stock fuel injectors eliminate the potential of the upgraded fuel pump? Or would upgraded injectors not be adequate with a stock fuel pump? and if both are true will that mean that both mods should be done at the same time? Any input would be great thanks!
Pump, and while your at it, rewire the pump. Cheap and easy to do. I saw about a 2.5 Volt increase when I did it.
DaveT
92GSX
  • Wanted 6 bolt NT water pipe
    • chrisman287
